Jun 11, 2015 10:24 AM UTC
Config.pro for realtime rendering in creo 3
Is there a config option to set to not display shadows on a transparent floor with the new Creo realtime rendering ?
Jun 11, 2015 5:51 PM UTC
In options>model display under real time rendering settings you have "Enable shadows cast from model onto specific room walls".
Uncheck it and you will lose shadows,
fgeiskopf1-VisitorAuthor
Jun 12, 2015 3:13 PM UTC
Thank you fo your answer. I have already found this entry in the options tabs.
I would like to know if there is an item in the config.pro (hidden or not) to set this by default (not enable shadows cast from model onto specific room walls).
Regards
2-Explorer
Jun 22, 2015 10:26 AM UTC
l have found only:
real_time_rendering_display --- Set the realtime rendering to project shadows/reflections on a transparent floor. Default value: transparent_floor
Try to test it...
