config.pro option automatically toggle extrude and remove materiel
A couple months ago I read on an article or saw on a video a setting I could toggle in my config file that made Creo automatically switch between extruding the sketch or removing material/cutting based on which direction I pulled the extrude. It was pretty simple but often did what I needed and was more time saving then one might think. However, I sort of stumbled across the article just trying to learn Creo so I knew next to nothing about config files and did not save the change and now I can not find the option or where I read about it for the life of me. I am trying to set up a config.pro file now and would like to include this feature so any help would be much appreciated!
Thanks, Zachary
Engineering intern
Creo Parametric 2.0
rcookAnswer
Set auto_add_remove to yes.
rcook1-VisitorAnswer
zeftink1-VisitorAuthor
Thanks!
