Nov 4, 2015 7:51 PM UTC
Config.sup
I am creating a config.sup file to create company standards moving toward.
I have approx. 14 users, working in Creo 2, where all software is loaded locally on each machine.. We have a file server that dishes out available licenses packs,, but I'm unsure of the location of a config.sup file needs to be. Where do I load the config.sup file so all users will have it load during log in?
Thank you, Dwayne
Nov 4, 2015 9:43 PM UTC
Config.pro files will load automatically from several folders, but the config.sup must be placed in the load point/text folder in order for it to be read.  Assuming that you are using a default install, that would be:
C:\Program Files\PTC\Creo 2.0\Common Files\MXXX\text
Replace MXXX with the build code that you are using.
To have all users use the same config.sup, you'll need to store it on a server and use a batch file to copy it into the load point when Creo is launched.
