Aug 17, 2010 6:54 AM UTC
config.win
Guru's
Is there a way of combining two config.win files?
Running WF3 M230.
Any help would be great.
cheers
Colin Down
Aug 17, 2010 10:35 AM UTC
The best way I know how is to have them in two different locations: Have the forst in the load point, the second in your start directory.
Aug 17, 2010 11:37 AM UTC
>-----End Original Message-----
Aug 17, 2010 12:39 PM UTC
1.
Start Pro/e with no config.win file.
2.
Load config.win #1 from one directory
3.
Load config.win #2 from another directory
4.
Save the results to config.win #3 in a third directory
Be aware, merging config.win files can produce unpredictable results.
They are supposed to be cumulative, and are, but not always in the way
you'd expect them to be.
Doug Schaefer
Aug 20, 2010 12:52 AM UTC
Or rename both to one.win and two.win. Then both can be in the working dir
and they can still be loaded one after the other.
One caution:
If config.win files  are amended by overloading one file after another, they
are subject to corruption, . Especially if any were born in an earlier rev
of WF. This can make things unstable.
If you are moving to a new version of WF, it's best to create a new one from
scratch.
--Glenn
On Tue, Aug 17, 2010 at 5:39 AM, Doug Schaefer <
> wrote:
>    1. Start Pro/e with no config.win file.
>    2. Load config.win #1 from one directory
>    3. Load config.win #2 from another directory
>    4. Save the results to config.win #3 in a third directory
> Be aware, merging config.win files can produce unpredictable results.  They
> are supposed to be cumulative, and are, but not always in the way you'd
> expect them to be.
> *Doug Schaefer*
