Configuration Creo 7.06 Hole, Specifications
How (where) could I find in my configuration of hole the following specifications for a Kato hole?
The problem is you can find them in Creo but not in the Hole-configuration.
  1. (Core) Drilling depth DRILL_DEPTH
       2. Thread depth THREAD_DEPTH
       3. Thread length THREAD_LENGTH
Thanks, in advance.
Djiki Wilfried
Community Moderator
Hi @WD_10959322,
Thank you for your question.
Anurag
TomU
  • The hard coded predefined rules are :
    • DRILL_DEPTH = 3 x DRILL_DIAMETER
    • THREAD_DEPTH = DRILL_DEPTH / DEPTH_RATIO
    • DRILL_DIAMETER and DEPTH_RATIO are 2 values available in the .hol file
CS99906 - Is it possible to directly specify the "THREAD_DEPTH" or DRILL_DEPTH values in a .hol file in Creo Parametric (ptc.com)
Add thread depth and or drill depth to .hol hole f... - PTC Community
