Nov 20, 2014 2:43 PM UTC
Configuration Options
I'm borrowing the works creo license so I can experiment with it.
I am hoping that the more advanced users of creo can give me any useful/good configuration options or detailing for drawings etc etc.
Nov 20, 2014 3:06 PM UTC
Ask direct questions. The configuration settings of Creo are 2 broad to give you any useful general answers.
There are 2 files to configure. The config.pro for modeling and some drafting and the details.dtl for specific drafting settings.
Nov 23, 2014 10:22 PM UTC
Okay, I suppose I'm looking for help with both of them.
I do undertand there are loads of settings that can be configured and its daunting looking at the list of them and knowing what to do.
For example I know you can have an automatic material removal config setting which does what it says.
So really I'm looking for any settings such as the above that can speed up my work other than clicking extremely fast.
2-Explorer
Nov 24, 2014 4:30 AM UTC
All of the config settings are there to give the user control over what they want to happen.
There aren't many, if any, that are plainly superior if they are changed from the default.
Even among the default ones, it is likely to be a guess on the desires of the typical users.
For example, even PTC changes their mind on the value of options: (per Creo 3 Datecode M010)
auto_add_remove
Creo 3: Allows Creo Parametric to automatically switch from add to remove of material for solid extrude and revolve during feature creation. Default NO
Creo 2: Allows Creo to automatically switch from add to remove of material for solid extrude and revolve during feature creation. default YES
Nov 27, 2014 12:19 PM UTC
The most important Creo options in the world:
save_dialog_for_existing_models no
sketcher_refit_after_dim_modify no
