Aug 12, 2014 9:40 PM UTC
Controlling Skeleton with Simplified Representation
I created a top Level Machine assy which has more number of Optional sub assemblies, so I can create "N" number of different machine configurations with combination of these optional sub assemblies. I created skeleton also for controlling optional subassemblies placement based on the machine configuration.
Now i am creating simplified representations based on machine configurations, just to show that combination's optional sub assemblies alone.
I want to change the skeleton input values based on the current simplified representation to correct the sub assemblies placements. so i don't have to key in the skeleton input values whenever i switch to different simplified rep
Please any one can explain me, How can i control the skeleton input values with Simplified rep.?
2-Explorer
Aug 18, 2014 12:02 PM UTC
Hello Ramesh,
if the component placement changes based on the subset of components, then this looks more like a task for family tables than represenations. Representations are allowing to switch components on/off. However, if you want to change their placement, you need to modify dimensions/features (of skeleton, assembly, etc...) and hence it is better to use family tables or Pro/PROGRAM functionality.
Gunter
Ramesh1-VisitorAuthor
Aug 22, 2014 10:09 PM UTC
Hi Gunter,
Could you please explain me how to use Pro/Program for scenario like mine...
Ramesh
2-Explorer
Aug 23, 2014 2:13 AM UTC
Until Gunter can get back, have a read through of the documentation about Pro/Program.
It is like a text version of the Model Tree with some assignment.
There are no loops. There are conditional statements, which is what makes it more capable than Family tables.
You can start here: http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/fundamentals/About_Pro_PROGRAM.html
Aug 26, 2014 11:00 AM UTC
Is it possible to make your skeleton a family table? If so and your variants are not unmanageable then the following strategy might work. (Note: this requires gathering assemblies(sub-assemblies) containing the systems as you will be overloading the top level assembly)
1) Top level assembly which will contain the simplified reps
2) Assemble all variants of skeleton instances into top assembly.
3) Assemble the applicable gathering assembly to the appropriate skeletons.
Notes:
  1. Since this model will have multiple skeletons and subassemblies, I recommend adding notes to the feature name column to define the conditions of use. This will make managing the reps easier.
  2. Do not use the simplfied rep to "substitute" the skeleton instance. (Use master rep of each skeleton in the model tree. The following areas have issues with this method: Creo model tree, Windchill structure tab, Windchill publisher, Creo View files, and I'm sure any visualization tool.) The reliable method is to include all the instances individually in the model tree!
4) Create simplfied reps as needed.
You don't have to have much programming knowledge to use this approach and it is reliable. In our case, we try to only do this if the variants are under 20. We had 60 skeletons in an assemlby and performance starting being an issue.
