Dale_Rosema
May 23, 2017 11:10 AM UTC
Corrupt .idx file?
I had an issue where the .idx file had been deleted and I could not save anything without crashing.
Several months later the .idx file was there, but possibly corrupted. After crashing, things worked again when a old one was reinstalled.
Same thing happened yesterday.
In this thread:
Re: Getting booted out of WF5/Creo
Martin Hanak talks of recreating the .idx file:
But when I try this, it crashes again. I thought maybe if I made a "new" one, things would be better.
Any thoughts?
(I did save a back up before trying this so at least I am not dead in the water.   )
May 23, 2017 1:15 PM UTC
did you test Update Index command with different family table model in different directory ? This test should tell you if the problem is related to specific model -OR- if it is general. If the problem is related to specific model, then you can ask PTC Support to repair it (this is my guess).
MH
MH
Dale_Rosema
Nov 1, 2018 8:52 PM UTC
We have switched to Creo 4.0 and that now works. I did not find an answer for WF5.0 though.
