Jan 6, 2016 1:21 PM UTC
Cosmetic thread lines on drawings
Does anyone know if there is a config setting to prevent the cosmetic lines for threads from showing up on your drawings when a view is placed.  I know I can erase them, but since we never show then, I would just like to not have them show up at all.  I've been searching the config files and have not been able to find anything for this.  Any help would be appreciated.
Jan 6, 2016 2:12 PM UTC
You could create a cosmetic layer and then hide it.
Jan 6, 2016 2:48 PM UTC
Thanks for the response.  I know there are several ways to eliminate them. I'm specifically looking for a config setting that prevents these from showing up at all.
Jan 6, 2016 3:10 PM UTC
in your config, you could put:
def_layer     layer_thread_feat     thread <or what ever layer you want it to go on>
This will auto assign cosmetic threads to a layer, here named "thread" and you can by default hide this layer
Jan 7, 2016 5:00 PM UTC
You might try fasthlr_drawing yes in your config.pro. As I remember, the reason we don't use it is that thread cosmetics didn't show in the drawing.
Jan 7, 2016 5:12 PM UTC
This setting did prevent it from creating the cosmetic lines for threads, but it also changed so everything comes into the drawing following the color from the model, instead of just being white lines.  Any idea why it did that?
Jan 7, 2016 6:59 PM UTC
I am not seeing the color problem, but pipe centerlines show where they were hidden before and edges of curves turn phantom or disappear.  I guess you don't want this solution.Your request just triggered some old recollections.fasthlr.png
