Creo 1.0 Config Files Load order & keeping them straight
- 4 replies
- 1546 views
- Translate All
I was just doing some testing.
What I did was add a few lines to the beginning of each of my config files. Like this:
!== Common Files Config.pro == <-- Indicates the Folder and the File loaded.
What I was trying to determine if Creo sees a config file that is in the <loadpoint>\Creo 1.0\Parametric\text Directory.
The answer is no, it will not see any config file in that directory. So all your loadpoint configs have to reside in the <loadpoint>\Creo 1.0\Common Files directory.
The only way to keep these config files straight and see which has which options is to begin each one with a comment. Then in the Configuration Editor, you tell it to show the options As Set. Hopefully PTC fixes this in Creo 2.0. Does anyone know when this is to be fixed?
[cid:image002.jpg@01CCDB6D.E486A7D0]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
