Aug 18, 2011 7:57 AM UTC
Creo 1.0 loads ribbons slow when certain config.pro options point to Windchill
Also testing Creo 1.0 Parametric here.
When I set e.g. start_model_dir to point to a folder in Windchill, Creo 1.0 takes approx. 1 minute to load the Part mode riibbon UI.
Without this setting pointing to Windchill the loading is at normal speed.
I also notice, that when this setting is not pointing to Windchill, the login to Windchill first appears after File > Open. When the setting is pointing to Windchill, the login appears during launch of the application.
Anyone able to reproduce this scenario?
Bjarne Frandsen
(Pro/ENGINEER Wildfire 4.0 M170andWindchill 9.1M060 on Windows)
