May 16, 2012 12:10 PM UTC
Creo 1 Working Directory
We have just upgraded from Creo/Elements Pro to Creo 1 Parametric. When trying to set the default working directory, Creo seems to always try to open files from my documents by default. I have the startup location set for the correct folder, but when you launch Creo and hit open, it brings the explorer window to my documents. Is there a config.pro option or something that could be overriding the startup location?
Any help would be appreciated.
May 17, 2012 7:04 AM UTC
Lou,
use config.pro option file_open_default_folder working_directory. It works in WF5 and also in Creo Parametric.
Martin Hanak
May 17, 2012 5:37 AM UTC
Hi
When you are setting start in directory to specific folder; please place your config files(Config.pro,config.win etc) in that folder.
After this you will not face this problem.
Try this and reply
Regards
K.Mahanta
Lou,
Martin Hanak
LouGeier1-VisitorAuthor
May 17, 2012 11:48 AM UTC
That was the option I was looking for. Thanks for the help!
