Mar 31, 2013 4:19 PM UTC
Creo 2.0 30 Day Trial - Quality Agent Error
I just installed the Creo 2.0 30 Day Trial, and when I fire up Creo I get the following error message:
"Creo Parametric is shutting down becvause it could not run the Quality Agent, which is required in this edition. If you call Technical Support about this problem, report error 0xc6000005."
Now, Quality Agent was installed with the entire install, and it looks like its doing what it does when I fire it up, and it has a tab for "Creo Parametric Trial."
Thanks for any help in sorting this out.
Apr 1, 2013 12:45 PM UTC
In case it is of any value to solving this, I also was sent an email from PTC that had a sw_license_email_(some number).dat in it, that had no email body or instructions.
Apr 1, 2013 4:44 PM UTC
Please contact your reseller and see if they can connect you with a right technical personnel. They can look at your screen and help get the issue resolved. I too had a lot of trouble when I 1st loaded the evaluation copy. They took care of the issues quickly.
Apr 1, 2013 6:21 PM UTC
Apparently, according to an IT guy here, Caterpillar is a direct PTC customer. So perhaps there is another person to go to at PTC? I don't personally have any service plan.
8-Gravel
Apr 1, 2013 6:52 PM UTC
Have you tried the soulutions presented here:
http://communities.ptc.com/thread/37231
Apr 1, 2013 11:51 PM UTC
I tried them now, no luck. Reinstalling quality agent from the install directory wasn't an option, as there is no file to do that in M040. Running as administrator doesn't solve the problem, nor does making the folder for quality agent not read only. I also verified that it wasn't an antivirus software issue. Not sure what else I can try or who I can contact. I'm not sure how this whole "somebody logs in and fixes my pc" thing works....
Apr 2, 2013 12:14 AM UTC
Start here... "have a PTC sales representative contact me".
http://www.ptc.com/company/contacts/
