Creo 2.0 difficult to load with borrowed licenses
I don't have a need to borrow licenses very often, but whenever I borrow a license the program takes many attempts to load up. I have to click the icon ~10 times in rapid succession and sometimes a single instance loads up, sometimes it's  2-3, or sometimes nothing at all happens. This is only an issue with a borrowed license and the program seems to silently exit. I am also running the latest version of 2.0.
We seem to have the same problem, when you borrow a license for Creo 2.0 (both M110 and M240 builds) the program doesn't start up in 1 try.
Indepently if you are connected to the license server or not.
Selecting a different license then borrowed and everything works ok, the same when the borrow expires.
Sometimes it looks like switching off Eset anti-virus software will help to lower the number of tries before you succeed to start Creo, other times it shutting down anti-virus doesn't seem to matter at all.
Did you get the issue resolved?
