7-Bedrock
Jun 20, 2014 2:15 PM UTC
Creo 2.0 File Search
We are currently using Creo 2.0 in a non-PDM environment temporarily. I have the search.pro setup, but it looks like it is not searching sub-directories of the directories listed in the search.pro. Do I have to list every directory explicitly???? I am hoping not. Is there a config setting that I am missing that allows for the search of sub-directoroes?
Jun 20, 2014 2:36 PM UTC
Yes, you need to include every folder explicitly. This actually can be used to your advantage if you archive different versions into sub-directories and don't want them to be accidentally retrieved.
