Mar 7, 2014 12:10 PM UTC
CREO 2.0 M090 drawing regenerate problem
- 4 replies
- 8071 views
- Translate All
Hello !
I am facing an issue on Creo 2.0 M090. When I open a drawing and its model, and change the model it's not been updated on its drawing, even after I use the REGEN command. I've tried it with and without my present config.pro configurations with the same result.
As an example, I'm sending a model and a drawing. The drawing doesn't reflects the model anymore. Opening the drawing and hitting the regen command it doesn't update the drawing. The only way I found to walk around the problem is to force a second unnecessary change, regen in the model + drawing, and them undo the unnecessary change.
Is there anyone facing the same issue ? Does anyone knows how to solve it ?
Thanks !
