Feb 28, 2013 6:56 PM UTC
Creo 2.0 Splash Screen starts, Xtop.exe closes
I am trying to resolve a desktop issue that I've recently upgraded to Creo 2.0.
The install went without issue and upgraded fine appearently.
But when attempting to launch Creo 2.0 parametric I only get the splash screen to launch, and then after a short while, 1 or 2 minutes I'd say the xtop.exe application closes without an error message.
There is nothing listed in the Event Viewer.
There are no popup errors.
I am running windows XP Pro, fully updated on a AMD Phenom II X2 555 with 2GB of RAM.
Any help would be appreciated.
Feb 28, 2013 8:01 PM UTC
That will be a customer support call with high priority. If it worked before, it should work again.
I will recommend trying a complete install from scratch. Uninstall everything (except the license server) and install from the downloaded files rather than the online install.
Good luck!
Feb 28, 2013 8:04 PM UTC
I've already run a complete unistall of creo 2.0 and wildfire 5.0. With a reboot, and removal of any remenant files on the system.
I was just typng up a support case to see if PTC would be of any help.
Thank you for the response though.
