Creo 2 crashing while opening drawing files
I am using Creo Parametric Release 2.0 and DatecodeM020
Jathin4-ParticipantAuthor
I got install Creo 7.0.9.0  along with Creo 2.0 M250, after that Creo2 drawing module is crashing, unable to open or create any drw in Creo2, so then uninstalled both Creos & reinstalled only Creo2, but still the same issue. All other modules are working fine except for drawing, please let us know if anybody faced similar issue & how it can be resolved’
1. Article - "Creo crashes when opening drawing file in Creo Parametric": https://www.ptc.com/en/support/article/CS200429
2. Discussion - "Creo 3.0 M140 Crashing on Drawings": https://community.ptc.com/t5/3D-Part-Assembly-Design/Creo-3-0-M140-Crashing-on-Drawings/td-p/497209
22-Sapphire I
We haven't heard yet if the suggested articles have helped you solve the problem - please post any new info.
One other thing you might try is to create a new drawing with no model, and select Empty, no Format.  This would create an absolutely most minimal drawing.  If that works and other areas do not, then that's a good clue.  If that doesn't work either, then it's the drawing module itself.
