Creo 2-m020, no learning connector???
- 3 replies
- 2339 views
- Translate All
I have a call open with PTC and am getting nowhere in getting it solved.
I have Creo 1.0-m050 installed. When I run it I get the following processes that run:
[cid:image003.png@01CDC18F.6610E600]
In the upper right corner of Creo I see the Learning Connector icon.
[cid:image001.jpg@01CDC18E.9CDBA6D0]
I also have Creo 2.0-m020 installed. When I run it I get the following processes that run
[cid:image004.png@01CDC18F.6610E600]
The Creoagent doesn't run.
The Learning Connector icon doesn't show up.
[cid:image002.png@01CDC18E.FE0CA210]
If I start Creoagent first, and then start Creo 2.0 it still doesn't work.
[cid:image005.png@01CDC18F.D8935230]
I have Creo 2.0 installed onto a network drive and I used the silent installer to install all the local stuff, including the creoagent. Like this:
rem ** Install the client Side software
rem "P:\Creo 2.0-m020\Training_Setup\creoagent_32_64.msi" INSTALLDIR="C:\ptc\Creo 2.0\creoagent" /passive
rem "P:\Creo 2.0-m020\Training_Setup\Thumbviewer_32_64.msi" /passive
cd /d "P:\Creo 2.0-m020\Training_Setup
start /w CreoView_Express_32_64.exe /vADDLOCAL="ALL" /qn APPLICATIONFOLDER="C:\ptc\Creo 2.0\CreoViewExpress"
rem ** Install the registry settings
regedit /s "P:\Creo 2.0-m020\Training_Setup\direct-created.reg"
regedit /s "P:\Creo 2.0-m020\Training_Setup\parametric-created.reg"
regedit /s "P:\Creo 2.0-m020\Training_Setup\simulate-created.reg"
Anyone have an idea??????????
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
