Aug 7, 2015 7:24 AM UTC
Creo 3.0 crashes while saving drawing into DXF.
Does anybody else have the same problem??
Not just this, Creo also crashes frequently while handling complex data.
Any solution?
sbapatAnswer
Sep 7, 2015 8:03 AM UTC
Checked with PTCSupport, Just Version specific issue. M030 did not have any problem saving into DXF.
Mahesh_Sharma
22-Sapphire I
Aug 7, 2015 5:52 PM UTC
Is this a reproducible exit with a specific data or with any of the data?
You may try latest datecode of Creo 3.0 or submit a case for Tech. Support with data and steps to reproduce the exit.
Aug 9, 2015 2:30 AM UTC
I regularly export DXF out of Creo 3.0 M020 drawings.  No issues at all.
Mahesh_Sharma
22-Sapphire I
Aug 25, 2015 5:39 PM UTC
Sanskar,
Any update on this? Did you try contacting support on this issue?
sbapat1-VisitorAuthorAnswer
Mahesh_Sharma
22-Sapphire I
Sep 7, 2015 1:40 PM UTC
Sanskar,
You may mark your reply as Correct answer for the post.
