Apr 24, 2016 3:28 PM UTC
Creo 3.0 Doesn't Open on Windows 10
I have a Lenovo G50-70 Laptop and I just installed the Student Version of Creo Parametric 3.0. The Install went normally, but when I open "parametric.exe," I get the spinning wheel icon and then the program flashes on the taskbar for a half-second then it completely closes. The task manager recognizes the program as it is starting up, when I get the spinning wheel icon. However, it is not recognized when everything closes. I don't know why this is happening, could anyone help me out here?
Apr 25, 2016 8:10 AM UTC
add the following option at the end of config.pro file. Edit this file on Wordpad.
graphics win32_gdi
MH
Apr 28, 2016 12:13 AM UTC
Thank you! However, whenever I attempt to add the option in "C:\Program Files\PTC\Creo 3.0\M010\Common Files\jlink\jlink_appls\jlink_param\config.pro," it says that I don't have access to the file to be able to edit it. How could this be fixed?
Apr 28, 2016 5:40 AM UTC
copy config.pro file into startup directory (see properties of startup shortcut, Start in field) and edit it.
You cannot edit "C:\Program Files\PTC\Creo 3.0\M010\Common Files\jlink\jlink_appls\jlink_param\config.pro" file because of access rights.
MH
Mahesh_Sharma
22-Sapphire I
Apr 27, 2016 3:50 PM UTC
Ben,
Did you get a chance to test Creo referring Martin's suggestion?
If still it is not working, you may write an email to -
