Oct 29, 2015 9:33 AM UTC
Creo 3.0 mapkey/ribbon issues
We recently upgraded to creo 3.0 m060 from creo 2.0.
One problem we are facing is that some mapkeys added to the ribbon stopped working.
The mapkeys work if we type the text on the keyboard, but adding them to the ribbon nothing happens. The buttons don´t do anything.
What the mapkeys do is open a config file and open a file.
This only happens in two computers. The others works fine.
Anyone experienced this?
Nov 3, 2015 7:34 PM UTC
Rebuilding a new ribbon from the scratch in Creo 3 has solved the problem.
Oct 29, 2015 11:42 AM UTC
Jose,
This is such an open question because we have no knowledge of your set-up configurations so with what little was offered, I suggest to see if the two computers share the exact same .ui and .pro files as the other ones that do work. Make sure that any local/user created .ui and .pro files are nullified.
ron
Oct 29, 2015 11:49 AM UTC
Sorry, I forgot to mention that all the computers use the same .ui and .pro files.
Oct 29, 2015 11:56 AM UTC
Jose,
can you publish problematic mapkeys ?
MH
Oct 29, 2015 12:12 PM UTC
Sure,
See attached files.
Mold.pro is a configuration file loaded by the mapkeys.
Oct 29, 2015 1:13 PM UTC
Jose,
I opened problematic_mapkeys.pro and found these mapkeys:
lingua
lingua1
lingua2
omfg
Note 1
I think that user is not able to launch lingua1 or lingua2. Creo can launch lingua, only. Suggestion: rename lingua to lingua0.
Note 2
mold.pro must be present in current working directory. Is this rule fulfilled ?
Note 3
mold.pro when edited improperly can get double extension mold.pro.txt. Such file can be seen in Windows Explorer as mold.pro. This can cause confision.
Note 4
I can test your files later.
MH
Jose_Costa12-AmethystAuthorAnswer
