Creo 3.0 Sketcher 'Text' issue
The text does not display and message is 'Sketched text produces degenerate strokes'.  I was able to sketch 4 different texts then the error message popped up.
Thank you in advance.
Which font are you using?
creed-41-VisitorAuthor
font3d.  What is confusing is I was able to create 4 different texts and then the error.
Each character is independent as to what it can do.
Taper extrudes are particularly vulnerable.
I too use the Font3D.
It is the most reliable of the outlined fonts.
Can you post an image of the offending text?
