Mar 1, 2016 7:35 PM UTC
Creo 3.0 Surface Free Form
What happened to the Surface Free Form and Solid Free Form commands in Creo 3.0?  Is there a config or hidden config to bring them back?
It was available in Creo 2.0
Is there a new equivalent version of this feature?
18-Opal
Mar 1, 2016 8:32 PM UTC
Hi Corey,
It appears that these options have been obsoleted in Creo Parametric 3.0, but you can still access them by setting the config option enable_obsoleted_features to yes.  Once you do that, you will be able to search for Surface Free Form and Solid Free Form in the Command Search or add them to a user-defined tab from the Customize Ribbon.
You can get more information via the following article:
CS180186 - Surface Free Form command under Model > Surface is not available in Creo Parametric 3.0
If you don't have a user name and password to login, you can create one here.
Amit
18-Opal
Hi Corey,
Amit
