Jun 6, 2016 12:40 PM UTC
Creo 3 Customization.ui
I have one user that his Creo will not hold the Window Settings when opening new parts, assemblies, or drawings in a new window. He has to Import the creo_parametric_customization.ui file every single time a new window is opened.
I have tried recreating the customization file, checked his personal config, and even reinstalled Creo 3 M090. Doesn't change a thing. Has anyone run across this issue yet?
Mahesh_Sharma
22-Sapphire I
Jun 6, 2016 9:12 PM UTC
Erik,
Try renaming the UI file (creo_parametric_customization.ui) to creo_parametric_admin_customization.ui and place that file in text folder under <Install Dir>\common files.
Jun 10, 2016 1:45 PM UTC
Tried this and still doesn't hold. No clue what is going on as everyone else has no issues with this.
Mahesh_Sharma
22-Sapphire I
Jun 10, 2016 6:39 PM UTC
Erik,
If you are in active maintenance, submit a case for technical support to look in this.
