Jul 20, 2015 8:07 PM UTC
Creo 3 installs without any reported errors, but will not launch?
Creo 3 installs without any reported errors, but will not launch ( M040, Win 7 64 bit). how do I fix it?
mwoozleyAnswer
Jul 20, 2015 9:15 PM UTC
Well I found a solution. The desktop icon was set-up by the installation to to run parametric.exe.  I changed it to parametric.bat and it works.
mwoozley1-VisitorAuthorAnswer
Jul 21, 2015 7:36 AM UTC
Mark,
just a note ...
I am confused by the fact that parametric.exe does not work and parametric.bat does work, because parametric.bat calls parametric.exe ...
Martin Hanak
Jul 21, 2015 11:39 AM UTC
I dunno.  Even thought the psf is in the same directory, maybe parametric.exe needs the location of the PSF
"C:\ptc\Creo 3.0\M040\Parametric\bin\parametric.exe" "C:\ptc\Creo 3.0\M040\Parametric\bin\parametric.psf" %*
