Oct 27, 2016 9:15 AM UTC
Creo 3 M090, Subject: Surface Finish symbol. Several users have reported that when using the surface finish symbol for No_Value, it does not display the symbol or allow to attach it.
The first time you use the surface finish symbol " no_value.sym" it works, however at some point it will not allow the selection of it and thus will not allow you to place it. if you copy " no_value.sym" and call it " no_value1.sym" it works again for a while, but keep doing it and the "symbol name" drop down fills up with more symbols of the same name with bracketed numbers after i.e. " no_value(1)"
So how do we keep this symbol consistantly working, and how do you delete the memory of the "symbol name" drop down.
Also tried in the Drawing properties the command 'user_command' as the option name, and 'delete_unused_symbol_defs' this does nothing to help.
I have also checked changing all the symbol related directories in the config.pro is set to the symbol location, to no avail either.
