Creo 3 m110 - Config export per current filter not working.
I was trying to export the Current Session config.pro, in Alphabetical order. What I got was the Current Session in As Set order.
Obviously Export Per Current Filter isn't working.
Anyone know a way to force it to export using the filters I specified?
davehaighAnswer
I opened a call with PTC on this. Here's the response.
David,
I have received your case concerning the config output.
I did some testing and the view shows different for each setting, alphabetical, as set, and by category, but the output is the same on all settings.  I then did some searching and found this article which states the sort order is not considered during export.
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=196052
Looks like a product idea is needed for this.
Find your call and track it at:
https://www.ptc.com/appserver/cs/view/call.jsp?n=13472098
You can also add notes and files here.
davehaigh13-AquamarineAuthorAnswer
David,
