Feb 17, 2015 11:21 AM UTC
Creo 3 Mapkeys
Guru's
I am currently going through updating and adding mapkey to Creo 3. I am having an issue when creating a new mapkey in my config.pro file. I used to be able to copy and paste and edit mapkeys in the note pad but for some reason this doesn't seem to work for new mapkeys. I can however edit old mapkeys fine.
But if I copy and paste an old mapkey and change the mapkey key (as in keystrokes) if doesn't work!
Has something changed or am I missing something....early start
TomU
Feb 17, 2015 2:52 PM UTC
Mapkeys are still editable, but the text they enter is not intuitive. Each letter is represented by an 8 digit code. This code is different for upper case, lower case, and where the number is entered (number pad or main keyboard area.) The letter/number displayed after this code is NOT necessarily the character that will be entered. (For example, the mapkey text will always show upper case characters even if the code is for entering a lower case character. To change the text that is entered, you must change the 8 digit code. Changing the displayed characters doesn’t do anything.
[cid:image003.jpg@01D04A8F.148650F0]
See more of my comments on this issue here:
Chris3
Feb 17, 2015 3:16 PM UTC
I'll bet this has to do with supporting special characters (periods, spaces and others in filenames) starting in Creo 4.
Feb 18, 2015 1:12 AM UTC
This more looks like a way to eliminate Mapkeys and editting of mapkeys and trail files. There is no way there are 1Billion unique characters, and sequential characters in ASCII aren't mapped in the example to sequential numbers.
Feb 20, 2015 11:57 PM UTC
None of the mapkeys that we have to add menu tabs and custom icons to the UI are working in Creo 3. Anyone know what needs to be done to make the old mapkeys compatible (without having to create them from scratch)?
Chris3
Jul 16, 2015 3:46 PM UTC
Mapkeys are never backwards compatible. They always have to be re-generated.
Jul 16, 2015 12:09 PM UTC
Has anyone figured out to nest a mapkey?  I have logged a case with PTC 4 days ago and have not heard back from them. (I miss the exploder)
Chris3
Jul 16, 2015 3:48 PM UTC
By nested do you mean one mapkey calling another? You can going to have to be a little more specific. As a trial I just created a mapkey that opens the file open dialog box and then one that cancels it and then a 3rd that calls the first 2 and it works fine.
mapkey oc %op;%cl; mapkey op ~ Command `ProCmdModelOpen` ;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER` \
mapkey(continued) `file_open:Ph_list.Filelist:<NULL>``;
mapkey cl ~ Activate `file_open` `Cancel`;
Jul 16, 2015 6:01 PM UTC
Christopher,
After looking at your syntax I realized that I forgot to add a ; after calling out the mapkey.
Mark
