Creo 3, Print Preview
Ctrl-P in Creo 3 takes you to the print preview window - is it possible to revert back to just going straight to the Printer Configuration window? We use pcfs to print, and the new functionality adds three new steps to printing drawings.
Was:
1. Ctrl-P
2. select appropriate pcf
3. OK
Now is:
1. Ctrl-P
2. Click Settings
3. select appropriate pcf
4. OK
5. Print
6. Close print preview.
I know I could work around this with mapkeys, but was wondering if there's a way to revert to the old functionality. Haven't been able to find a config option, but maybe I've missed something.
Dave
I agree Ctrl-p should print not show the preview.  have you created a mapkey to get around this?
18-Opal
October 25, 2016
Hi David,
Unfortunately there is no setting to change the behavior.  There was a change made to the specifications in Creo 3.0, that caused the change in the UI.  I would advise you to create a Product Idea to see if a setting can be added to get the old UI.
Amit
