Creo 4 Failed to connect to server
I have recently installed Creo 4(M80) and it fails to run with error (-96) Failed to connect to server. Server is down or unreachable.
The thing is that i am at home connected via VPN to the network where licencing server is running. However when i brought my PC with me and physically connected my to the network, everything ran just fine.
I tried running it with firewall disabled on my PC as well as on the licensing server, but i keep getting the (-96) message.
Any suggestions what to try next?
P.S. Don't mind the (-21) message
Try the above mentioned advice.
Mahesh_Sharma
22-Sapphire I
@Dawek
As this is due to communication, check connectivity on port 7788 and also check for any other firewall blockages in vpn.
CS21768
Dawek1-VisitorAuthor
Thanks for the reply Mahesh, but as I'm not that much IT server guys, i have no idea how to check connectivity to the 7788 port, neither know how to check for firewall in the VPN. I was only able to ping the server via command line.
Also the article you linked is said to be for maintenance only, where I don't have access.
