CREO 6.0.4 VS 6.0.5
I have noticed that CREO 6.0.5 os released. Where I can find the improvement s made?
Hope that PTC have worked a lot in stability.
You do realize that Creo 6 is already out-of-date and is out of support.
Once Creo 7 was released, Creo 4, 5 & 6 support ended.
Don't agree with that since it takes time to plan a migration to a new release when using Windchill.
But it is what it is.
There should be a What's New document with the new release.
There may be a Update Tool that compares your current version to the new version and lists the changes. Don't remember the exact name of it.
T_F16-PearlAuthor
I think it's to soon to upgrade to CREO 7. I have started working with CREO 6.0.2. and definitely, it was to soon.i haven't seen a so unreliable release. It became better with 6.0.3 and 6.0.4.
I started using CREO 6 coming from CREO 5.0.5, and I never achieved the same stability that I had in CREO 5.
I start using CREO in 5.0.5 coming from CATIA. I should say, that CATIA was the most robust and reliable cad software that I hever used. And CREO 5.0.5 wasn't Equal in stability, but was ok. In 6 it was always a step backwards.
I think I won't upgrade to Creo 7 before 7.0.4. and plus there is also windchill. I'm using 11.0
Windchill 11.0 does not support Creo 7.
You will need a Windchill upgrade to 11.1 or 11.2 before you can move to Creo 7.
Creo 5 & 6 are not supported on Windchill 12.0.
https://www.ptc.com/support/-/media/7D7FD7E6AF4345EB966D59ADD7F1316C.pdf?sc_lang=en
