AndrewDunk
6-Contributor
Oct 28, 2026 10:42 PM UTC
Creo 7 to 13.4 upgrade guide: what would you add?
Hi everyone, I’m Andrew at TriStar. A customer’s question about moving from Creo 7 gave me the idea to put together this guide covering newer capabilities. There’s so much out there, I wanted to simplify a bit.
I used AI to help build it. I can’t claim this is PTC’s or anything. Just a detailed doc pulling links and info together.
For anyone who upgraded recently is there anything you wish you checked before you did? I’m sure I missed some things, would love to beef this up even further.
Any advise is greatly appreciated!
Andrew Dunkelberger | TriStar
kdirth
Oct 29, 2026 1:15 PM UTC
One of my favorites from upgrading to 12 from 7 is sketched hole placement.  I believe it was added in 8.0.  You can sketch a rectangle to make a mounting pattern in the hole tool.  One downside is the diameter is tied to the first point/end point of the sketch and cannot be moved in the drawing.
AndrewDunk
6-Contributor
Oct 29, 2026 5:11 PM UTC
Oowe thanks, I’ll have to incorporate this in my next rev!
- Andrew "Dunk" Dunkelberger
kdirth
Oct 29, 2026 6:20 PM UTC
Here is my document on changes between 7 and 12 that I liked or found helpful and shared with coworkers.  Just a list of those things that I found in the what's new list in each versions help center that I liked or found helpful.
Nov 2, 2026 8:57 AM UTC
Hi Andrew
Nice work !
To get the extensive list of updates the reference tool is the update advisor : https://support.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
Interestingly it connects the dot with the SPRs that initiated the update.
I’m curious though what LLM you used and the prompts that you entered.
AndrewDunk
6-Contributor
Nov 3, 2026 4:04 AM UTC
Thanks, yeah that’s smart to call out the update advisor and specific fixes too!
I lean ChatGPT astra for collateral like this. It was a through a lot of iterations of “Bring these version comparisons, help pages, video pages, presentations into one practical reference guide. Focus on usability, not just marketing. Organize it by workflow and extract images where you can only when there is factual evidence linked to support. Make the guide easy to navigate.” ETC ETC ETC.
AndrewDunk
6-Contributor
Nov 3, 2026 4:11 AM UTC
If i were to reverse engineer a bit, it might go something like
“Create a polished, practical Creo 7→13.4 upgrade guide for engineers who know Creo 7 and want to understand what will actually improve their daily work.
Use the supplied customer-facing reference material and official PTC documentation. Verify feature availability and release attribution against primary sources. Flag anything you cannot verify. Don’t invent capabilities, licensing requirements, compatibility assurances or productivity savings.
Organize the guide by workflow rather than release: everyday modeling, assemblies, drawings, sheet metal, surfacing, MBD, simulation, manufacturing and data exchange. Put a clickable “Browse by workflow” section first, followed by the most useful upgrade highlights.
For each selected improvement, explain:
  • What changed compared with Creo 7.
  • Why an engineer would care, using a concrete example.
  • Where to find it and a simple thing to try.
  • The applicable release, prerequisites, licensing caveats and limitations.
  • A direct source link, clearly labeled as documentation, article or video.
Prioritize meaningful improvements and easy-to-miss usability changes. Include practical migration considerations such as mapkeys, configuration settings, drawing defaults and legacy-model behavior. Keep distinct features distinct, and avoid repeating the same improvement across sections.
Use relevant screenshots or diagrams with captions and source attribution. Don’t present an older interface as the current one. Remove customer names, internal details and organization-specific file paths.
Include a concise upgrade-validation checklist covering representative models and drawings, regeneration, assemblies, mapkeys, publishing and CAD/PLM compatibility. Explain where release notes and Update Advisor help. Don’t imply that documentation review guarantees a trouble-free upgrade.
Write like an experienced, helpful colleague: plain language, specific benefits, no marketing filler or unnecessary commentary about when a source or comment was created. Keep the main guide easy to scan and put deeper detail behind links.
Deliver an editable Word document and a linked PDF with consistent typography, useful visuals, page numbers, working navigation and back-to-top links. Before delivery, check technical claims, links, duplication and terminology; render and inspect every page for readability, clipping and awkward layout. List any unresolved factual questions separately for my review.”
Nov 2, 2026 1:33 PM UTC
Maybe add something about mapkeys being removed from the config.pro file to mapkey.pro and the file location.
AndrewDunk
6-Contributor
Nov 3, 2026 4:06 AM UTC
Page 7 yep! Funny you say this, because I left a client today and this was the first thing that jumped out to them as we were discussing infrastructure.
