Creo Blank Model Check Report
I am using Creo Parametric 7.0 7.0.2.0
Every time I save a drawing I get this “Model Check Report” blank dialog window that opens on the left side of the screen and doesn’t close until I hit the “X”.
Here are the errors that I faced
Blank Model Check Report.
Hello @VC_9931252
Thank you for reporting this issue to the PTC community.
Based on your comment it seems that such issue is related to specific drawing in this case.
Can you confirm that such ModelCheck blank report is data specific, or do you reproduce when saving all your models?
BR
Jean Claude
