Creo Crashing on Dell Precision 7560
I am using Creo Parametric Release 5.0 and Datecode5.0.0.0
I recent have a new laptop Dell Precision 7560 (graphic hardware NVIDIA T1200 Laptop GPU). experiencing Creo crashing during save or regeneration models about two weeks ago. The crashing be progressing day of day. At the beginning the crashing happened on different model from time to time. Since Oct 17th it started consistent crashing when tried to open the main assembly model. My Old laptop is Dell Precision 7510 (graphic hardware NVIDIA Quadro M1000M). I tested the same models on the old laptop. It's opened and running very well in Creo on my old laptop. So that means not the model with corrupted or other issue cause the crashing, But something else.
@SX_10270465 wrote:
I tried removed all config.pro and even created new workspace download the model. none works.
try to use config.pro containing single line
graphics win32_gdi
If this setting resolves crashing then the problem is related to graphics card drivers. Remove the above option and experiment with drivers. Start with the oldest ones.
StephenW
Try removing all the config.pro , creo_parametric_customization.ui, config.sup to make sure it isn't a specific setting
Try updating the graphics driver to the certified driver
http://support.ptc.com/partners/hardware/current/support.htm
or the latest released graphics driver.
Suggestion ...
If you find the right graphics driver then disable automatic driver update !!!
See https://superuser.com/questions/1507210/how-to-stop-windows-from-updating-my-intelr-hd-graphics-630-driver page for inspiration.
