Creo Elements Direct modeling express 4 Annotation crashes
I´ve been using Creo Elements direct modeling Express 4 (64 Bit) for a few weeks on windows 8 without any problems.
But now the "Annotate" constantly crashes with "Activation of module "Annotation" failed: "The view label configuration is incorrect. Check the configuration file for syntax errors."" and
"LISP error:
NIL is not of type NUMBER."
I´ve reinstalled everything (even with clearing registry and user folders from old configurations) but that didn´t help.
When I look at the Console it says:
FATAL ERROR: DOCU_INQ_OBJ_TREE returned NIL
Warning: Cannot set tree pointer for tree 'AM-BROWSER-TREE'!
a few times.
I Would be really happy if someone can help me.
Thanks and kind regards
Carsten
Tested a little further and even Creo Elements Personal 3.0 Shows the same behaviour: When starting annotate it crashes with the Lisp error.
I would be really glad if someone can help.
Carsten
