Aug 18, 2016 6:00 PM UTC
Creo Elements Direct Modeling Express 6.0 -Java issue
I downloaded two days ago the software and I can't use the on line Help.
A warning popup window opens with this message.
" the registry refers to a non existent Java Runtime Environment installation or the runtime is corrupted"
my OS is Windows 10
java-runtime-environment_8u102_fr_121472_32 is installed
Any idea to fix the problem?
Patrick
Aug 22, 2016 1:33 PM UTC
Hi Patrick,
for me this has helped:
- deinstall PTC and Java
- install PTC and run the help
- then displays an error message that Java is needed and the Java installation page opens
- download and install Java
- now the help works fine
I hope you can understand this, my english is not the best
Regards
Harald
Aug 22, 2016 5:08 PM UTC
Hi Harald,
IT WORKED
It wasn't obvious. Thank's a lot
Patrick
