Sep 25, 2014 2:34 PM UTC
Creo Installation
In my past job, the admin created a script to check and pull the Creo (WF5) and any updates using the shortcut on our desktops.
I am in a new job and we have a need to install the latest update to ~100+ folks at my location. I have asked the IT here to write a script to do basically the same. I was told they do not have the resouces here so I'm on my own.
With that being said, is there a tool or software I can use to basically do the same without having IT to write a script?
* Shortcut that user will select to run Creo
* if there's an update copy the latest update and override the config.sup/pro etc
Thank you all in advance!
Calvin
