Creo issue pinning to task bar
- 3 replies
- 6162 views
- Translate All
I recently installed Creo 6, and after installation created a shortcut on the windows 10 taskbar. The target is my install ("C:\Program Files\PTC\Creo 6.0.0.0\Parametric\bin\parametric.exe") with the start in set to my working directory. Creo 6 launches with all the correct configurations, but shows up in the task bar ungrouped with the shortcut and shows up as "Creo 5".
If I right click on the open windows icon in the task bar it says "Creo 5" and if I click properties on "Creo 5" I get shortcut properties listing the target as "C:\Program Files\PTC\Creo 5.0.0.0\Parametric\bin\parametric.exe".
Where is this coming from? I did a full uninstall of Creo 5 prior to installing 6. I cant find any system/environment varriables pointing at this path, or any registry entries pointing to Creo 5. The Creo 5.0.0.0 directory does not exist either.
