Mar 22, 2013 6:21 PM UTC
creo launching problem
I want to launch the Creo Element, it gives a busy symbol for few seconds,the program does not starts and goes away. What do I do? Is there any problem with config.pro or something else.I have window 7.
Mar 22, 2013 7:01 PM UTC
Hello David. This sounds like a compatibility issue. Is this the 1st time you installed the software or have you had it work successfully before?
Have you modified the default config.pro?
DavidKhan1-VisitorAuthor
Mar 23, 2013 1:47 PM UTC
No i have used it before on the same pc and the same window 7 and havent edited any thing.
Mar 23, 2013 4:51 PM UTC
I might suggest an automatic driver update may have done this. Can you log a case with PTC Support?
You could try re-installing the software including the license server.
Is this the Elements Direct or Parametric?
SamuelBrantner
Apr 4, 2013 3:44 PM UTC
Maybe you didnt install all needed files or have a bad setup. Compare the number of files from a working installation with yours. i had that problem once
Greetings Sam
