Oct 3, 2018 2:12 PM UTC
Creo license Feature names
We are installing new subscription licenses (updating from perpetual) and I need to inform users how to use the reconfigure command to update their startup file. I'd like to make it clear to users what licenses they will see when they run it. I believe that the feature name for Creo Engineer II with Advanced Assembly is PROE_EssentialsIIM. Does anyone know the feature name for Creo Engineer III?
20-Turquoise
Oct 3, 2018 3:30 PM UTC
From our license files:
Creo Essentials = PROE_EssentialsM
Creo Essentials Team = PROE_EssentialsIIM
Creo Engineer III = PROE_EngineerIII
20-Turquoise
jim110-MarbleAuthor
Oct 3, 2018 4:28 PM UTC
Thanks Randy!
Oct 4, 2018 7:32 AM UTC
if you open your license file in Notepad, you will see Summary Table containing Feature names and Product names. See example below.
#**************************************** Summary Table *******************************************************
#                       PTC Host ID 00-11-22-33-44-5
#FeatureName            Qty        Product                            Release   Type    Expiration     Contract
#PROE_EssentialsIIM       2     Creo Essentials Team                     Creo 5.0 Flt Lic mm-ddd-yyyy xxxxxxxx
#PROE_EssentialsM         4     Creo Essentials                          Creo 5.0 Flt Lic mm-ddd-yyyy xxxxxxxx
Jan 21, 2019 12:21 PM UTC
Good morning,
is it possible to customize the license file name to clearly distinguish the different types in the list of floating licenses?
Andrea
Jan 20, 2019 11:23 AM UTC
When I reserve a floating license, the window with the list of available
licenses appears.
Instead of setting a custom name manually in each client, I would like
it to be displayed directly from the license name set in the server.
Did I explain myself better?
