Creo licensing problem (Starting...)
I downloaded the 6.0 version, but by installing I can't activate my license (it's a .txt file from my school). Under status label it writes "Starting...", I wait long time, but nothing change, so I can't click next. A saw replies for my problem, but nothing helped.
Thanks for helping!
You should open a case with PTC Technical Support for assistance.
Abhinav
Thanks for helping!
open your license file on Notepad. Does the file contain following lines?
SERVER __HOSTNAME__ PTC_HOSTID=xx-xx-xx-xx-xx-xx 7788
DAEMON ptc_d __PTCD_PATH__
xx-xx-xx-xx-xx-xx represents MAC address of your network card
If the answer is YES then check whether MS Visual C++ 2013 Redistributable Package (Update 5) package is installed on your PC.
"Starting..." status can also mean that FLEXnet is already installed on your PC and you are trying to install it again using current installer functionality.
The license file include the mentioned 2 row, I tried again the licensing, but now status bar writes NOTHING (neither Starting).
what Creo version did you install before Creo 6.0 ?
Go to C:\Program Files\PTC\FLEXnet Admin License Server\bin directory, run ptcstatus.bat and upload picture of Command prompt window.
Open Services and look for lmadmin_ptc service. Is it available ?
Please just answer my questions ... I'll send you additional information according to your response.
