Jun 10, 2013 2:59 AM UTC
Creo Parametric 2.0 in Vista?
I notice in the system requirements it jumps from Windows XP to Windows 7. Can I not run the 30 day trial on my Windows Vista Computer?
Jun 10, 2013 6:02 AM UTC
Joshua,
I think Creo will run on Windows Vista.
Martin Hanak
Jun 10, 2013 11:20 AM UTC
When attempting to start Creo Parametric, there's a small screen which says "message" in it and an "Ok" box, but it disappears quickly and nothing else happens. I figured it was because I was running Windows Vista. Any ideas on what would have caused this?
Jun 10, 2013 11:38 AM UTC
Joshua,
can you upload the screenshot of that message ?
Martin Hanak
Jun 17, 2013 10:49 AM UTC
Am running Creo 2 on a toshiba laptop with vista business... with no problems.
Do you have full admin access too your computer or are you a standard user? i have found that sometimes vista blocks programs processes. try right clicking on the creo parametric icon and choose run as administrator and see if that helps. other than that i'd suggest reinstalling using the run as administrator and make sure your antivirus is disabled or set to ignore creo during install.
hope any of this helps gd luck
Gary
