Creo Parametric 7.0.6.0 is unable to open
I am using Creo Parametric 7.0 7.0.6.0
After Successful installation in my machine I cannot open Creo Parametric 7.0
Here are the errors that I faced
This App Can't run in your PC
To find a version for your PC, Check with software publisher
    Try the solution from this article - "This app can't run on your PC - to find a version for your PC, check with the software publisher": https://www.ptc.com/en/support/article/CS332423
