Creo Parametric - Dummy Dependencies
By default - if I replace a component i Creo the system will still recognize the old components as an dependency to the main assembly. I can't see why PTC doesn't make the remember_replaced_components config to be no by default. it will reduce a lot of pain for many customers.
However. Dependencies of the type "Dummy" is created all the time (e.g. independent copy geometry, merge/inheritance, mirror and so on). Is there any why to use e.g. ModelCHECK or similar to always brake dummy dependencies? If not. Would it be possible to use JLink to create these functionality?
/Jonas Fransson
