May 22, 2025 11:38 AM UTC
Creo Parametric in a Container/VM/DaaS
I'm a CAD manager for a large department.  Over the years the department has purchased CAD/Engineering laptops in batches, so the hardware/firmware/etc. is all over the place.  I'm trying to find a way with either a Docker ore Kubernetes, or something that would be able to run the same on every machine, I'm thinking of some sort of virtual environment that takes all the variability out of it.  Additionally it would allow me to sandbox software upgrades, settings changes, config.pro setting changes and so on before deploying to a group,  I have 20 drafters.  We run Creo 9, Windchill 13, but we also run Solidworks 22, and ACAD 24 on occasion.  Is there any solution that fits this?  I looked at VM's with a type 2 hypervisor VBOX, but it requires installing another OS in it to install the CAD software burdening the system even more.  I think that would be to resource intensive and the juice wouldn't be worth the squeeze.  Any advice would be appreciated.  Even pointing me in a direction to research would be a great help.
thanks in advance.
Catalina
Community Manager
May 29, 2025 9:21 AM UTC
Hi @ptc-6109739
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
Rafael Bova
3-Newcomer
Nov 17, 2026 3:45 PM UTC
Hi ​@ptc-6109739
I understand what you’re going through. PTC does provide standalone solutions for many of the challenges you’ve mentioned.
However, setting up this infrastructure will be quite a task.
My (not-so-popular) suggestion: consider migrating to Onshape. Full stop.
You’ll find all the solutions you need there, including an MCP server to help your team get used to custom tools they might already have on CREO.
