Creo Parametric Java examples not working
I am using Creo Parametric Release 8.0 and Datecode8.0.3.0
Having succeeded in running the Java examples (Tools - Utilities - Auxiliary Applications says it is running), the examples do nothing? There is no difference in the ribbon, no indication that anything changed. Starting or stopping the examples through Tools - Utilities - Auxiliary Applications makes no difference.
    rghadgeAnswer
    @JVerhagen78,
    Make sure you have licenses #333 + #334 OR #14 + #335 added to your *.psf file.
    Make sure you do not modify existing creotk.dat file.
    Place shortcut of Creo Parametric at location "C:\PTC\Creo_8\Creo 8.0.3.0\Common Files\otk\otk_java\otk_java_examples". Remove path mentioned in Start in field of Creo's shortcut properties.
    Launch Creo from this shortcut and check if the issue gets resolved or still persists.
    @JVerhagen78,
    Could you please share paths of examples which you tried loading in Creo?
    Also, share snapshot of Auxiliary Application dialog after loading sample application.
    rghadge17-PeridotAnswer
    @JVerhagen78,
