9-Granite
Creo Performance in VDI
One of the team is using Creo in VDI (Virtual Desktop) environment & facing performance issues when tried to open assemblies and drawing files. Kindly share some best practices to enhance the performances.
Naresh
Please note the actual CPU, the number of cores is irrelevant, Creo is mostly single threaded so what you really want to do is to check the cpu single thread performance here https://www.cpubenchmark.net/ . If this is a server based VDI, as most are, then they usually use Xeon processors which have large variability in their single thread performance, most are very poor.
Some discussion on this - "Virtual Desktops for Creo - Questions?": https://community.ptc.com/t5/System-Administration/Virtual-Desktops-for-Creo-Questions/td-p/855
Naresh
please provide more details concerning "performance issues".
NareshJ9-GraniteAuthor
9-Granite
Hi
Below are the details of VDI. Kindly suggest.
Attribute
Value
CPU Cores
16
Memory
64GB
vGPU
nvidia_a40-8q
hard Disk
350GB
OS
Windows 11
Naresh
I expected a question or problem description.
