Apr 3, 2013 2:06 PM UTC
Creo/pro2(m030) NOT STABLE
We switched from proe wf4 m210 to creo/pro2 m030 3 weeks ago and experiencing a lot of crashes on the very basic functions:
file save -> intermitent crash or lock up
file save as-> intermitent crash or lock up
switching between creo windows -> crash
PTC has already multiple SPRs opened on these issues - to be resolved in m050 or m060
D
Dmi3U15-MoonstoneAuthor
Apr 26, 2013 3:57 PM UTC
So, it is 4/26/13 and I am downloading m050 now (it was supposed to be out 4/17/13, just showed up today in the downloads)
Let’s see…
Apr 26, 2013 5:59 PM UTC
I actually downloaded it on the 24th. Only 1 week late.
Steve G
Apr 26, 2013 7:00 PM UTC
So I downloaded it, as in the file called
MED-100WIN-CD-390_M050_Win32-64.zip & setup.exe does not want to start in
Win7 64. Did I grab the wrong file? It claims to be both 32 & 64 unless
I am reading it wrong.
Thanks & have a good weekend all,
Joe S.
2-Explorer
Apr 26, 2013 7:03 PM UTC
We are having the same problem, opened a call with PTC and an SPR has been opened. We got around the problem by overwriting the M050 setup.exe with the one from the M040 build!
Ron
Apr 26, 2013 7:11 PM UTC
All,
It is not a PTC related issue, it is a Windows 7 extraction issue. You can
only use Winzip to extract the PTC files. We have ran across this with
other zip files and realized the same thing with PTC files.
If the file was created in Winzip, you can only use Winzip or 7zip to
extract the files. Windows 7 extraction corrupts the files that have been
zipped with Winzip.
