creo response is too slow after launching
I am using Creo Parametric Release 4.0 and DatecodeM060
Creo response is too slow after launching. After a minute, the xtop process has to be killed since Creo stops responding.
The client machine & the license server are on two different networks but have an IPSEC tunnel to establish connect with each other.
In the Std.out file, I see the below entry repeated multiple times.
Connection restored with License Server (#)
    Creo becomes irresponsive in a tunnel configuration and you found the error message Connection restored with License Server (#) in the std.out. This makes the session unusable.
    When searching the error message in our knowledge you will find two interesting articles:
    Finally this conversation tells that some anti-virus system was cutting the tunnel.
    When you gave it a look come back and update?
